Thread: 2004 gtp with bad piston
Results 1 to 3 of 3
cryott 2004 gtp with bad piston 02-09-2013, 09:16 AM
Scottydoggs Re: 2004 gtp with bad piston 02-09-2013, 11:34 AM
dsmuts Re: 2004 gtp with bad piston 02-09-2013, 09:33 PM
  1. #1 2004 gtp with bad piston
    Feb 2013
    greenfield in
    i have a 2004 gtp with 153,000 miles on it. it has ran flawlessly since new. last week on the interstate i stepped on the gas pretty hard and it made some noise. i drove it to the shop that has always serviced it, they hooked it up to the scanner and it said the # 1 cylinder had 57000 misfires. compression check showed no compression. also sparkplug was smashed. valves are intact. has anyone else had this problem. if i replace the engine does it have to be a series 3 . will a supoercharged engine out of a 2002 buick work thanks
  2. #2 Re: 2004 gtp with bad piston
    yup you chipped a piston. it happens. you run 91 or higher octane?
    yes you can use a old s 2 engine, id swap your lower intake and blower on it for ease of install, and the older engine will most likely need intake gaskets done anyway.
    you will need to swap a few other parts to the donor engine as well, (oil pan if your is al) oil filter housing, the alt and alt bracket. and i think you'll want to reuse your injectors as i dont think the older injectors will clip into your newer harness.
  3. #3 Re: 2004 gtp with bad piston
    I'm getting ready to do the same thing. Good luck on your swap.
  1. Busted piston!!!!
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2013, 11:10 AM
  2. clutch piston?
    By murp9302 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 10:53 PM
  3. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
