Thread: Exhaust leak from resonator
Results 1 to 14 of 14
  1. #1 Exhaust leak from resonator
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    So I have a bad exhaust leak and my car is starting to sound like a rice burner.
    I talked to a guy at a muffler shop today he said is was my resonator its right underneath the front passengers. And also said that its throwing off my o2 sensors and that why I'm getting bad mpg
    Let me know what you think cause I thought the resonator doesnt have anything to do with mpg
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: Exhaust leak from resonator
    Res doesn't have any effect on gas mileage. Just replace it with a glasspack
  3. #3 Re: Exhaust leak from resonator
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    if the leak is after both o2's it shouldnt really effect there readings,
    i dont think youll EVER gain mpgs from a exaust leak.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  4. #4 Re: Exhaust leak from resonator
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Sorry to jack the thread, I was just about to make a thread, but I have a 3" catless downpipe and stock exhaust, if I put in a 3" glasspack in place of the stock resonator, would my mpg go up? It's only $50 for one so it's probably worth the expense I would think? I'm not wanting it to be loud though.
  5. #5 Re: Exhaust leak from resonator
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by LS1GTP View Post
    no, i find that very unlikly
  6. #6 Re: Exhaust leak from resonator
    go buy a glass pack muffler, its 25 bucks, take it to the muffler shop and tell them to weld it in place of the res. you want 2.25 in and out lets.
    if you have a U bend, have it removed while they are welding stuff.
  7. #7 Re: Exhaust leak from resonator
    Sep 2012
    Clarkston, MI
    Anyone else have an opinion on this?
  8. #8 Re: Exhaust leak from resonator
    wont do a thing for mpg, as your still reducing it back to 2.25, stock pipe. even if you went 3 inch the whole way i dont think it would add up to much. especially on a stock engine.
  9. #9 Re: Exhaust leak from resonator
    truth ^^
  10. #10 Re: Exhaust leak from resonator
    Apr 2012
    Goderich, Ontario
    A glasspack is defiantly louder then a resonator. They don't absorb sound like a res. but add a deeper tone and reduce drone/ rasp.
    -Paul Walker
  11. #11 Re: Exhaust leak from resonator
    Sep 2012
    Clarkston, MI
    Ok thanks guys.
  12. #12 Re: Exhaust leak from resonator
    Jan 2013
    Grand Rapids, Michigan
    My resonator had like a dime sized hole in it and actually sounded pretty sweet! It got bigger and bigger and I eventually got pulled over for it. Cheap fix though
  13. #13 Re: Exhaust leak from resonator
    GTP Level Member joshv's Avatar
    canada
    dont need res, straighht pipe it
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  14. #14 Re: Exhaust leak from resonator
    Nov 2011
    NY
    The mess I just fixed... Lolz!
  1. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. resonator, exhaust help
    By BIGTMANE in forum General Tech Discussion
    Last Post: 08-15-2010, 01:35 PM
  5. resonator exhaust question!
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 03:30 PM
