Thread: add on supercharger
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
  1. #1 add on supercharger
    Jan 2013
    Tolono IL
    would i have to lower my compression in my GT if i put on a supercharger? or should i just turbo it?
  2. #2 Re: add on supercharger
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Depends if you are going for the fastest your car can go or not. If you just want a little more HP just supercharge it but if you want it to be fast over time and want to really build it up go turbo.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Re: add on supercharger
    Jan 2013
    Tolono IL
    i been thinking about turbo but my friend is telling me to put a supercharger on it
  4. #4 Re: add on supercharger
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Go turbo.
    Its the best way to go.
    And in the long run, it will be cheaper too.
  5. #5 Re: add on supercharger
    Upfront the turbo will be way more but in the end you will be happier with the turbo over the supercharger I think.
  6. #6 Re: add on supercharger
    Jun 2011
    Quote Originally Posted by burgundybullet View Post
    Top swap kit + Modding on top of that, will cost more that a turbo kit up front.
    Just a top swap kit will be cheaper but that gains compared to a turbo is nothing.
    Depends on far you want to the build.
    Hands down, turbo is a much better option.
  7. #7 Re: add on supercharger
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  8. #8 Re: add on supercharger
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Put on a PLOG, HAI, Downpipe, and an HV3. Then get a tune. Should add some noticable pep and MPGs.
    Run that setup while saving for a z7 kit and a fully built TEP 4t65e.
    When sufficient funds are obtained for not only parts and labor but also some for when/if things go wrong, then install the turbo and trans in one shop trip.
    Then you would have a nice flowing and powerful set up.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: add on supercharger
    Jan 2013
    United States
    Turbo! Cheaper. Easier to maintain & tune. And you get more for the money. Problem solved. Less hard it is on your car too.
  10. #10 Re: add on supercharger
    Quote Originally Posted by Brendon View Post
    a good turbo is in no way cheaper then a top swap. even adding headers, top swap is still cheaper.
    I fail to see this logic being correct
    04 Comp G.
  12. #12 Re: add on supercharger
    Jan 2013
    Tolono IL
    how about a top swap and a turbo? what kind of gains am i looking at there?
  13. #13 Re: add on supercharger
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    twin charging that is called. and not many people have done that. expensive. hard. hard to do. hard to tune
  14. #14 Re: add on supercharger
    Reading answers alot.
  15. #15 Re: add on supercharger
    Jan 2013
    Tolono IL
    what about just a top swap? or just a turbo i looking for the cheapest but still get good results
  16. #16 Re: add on supercharger
    antioch ill
    top swap will be about 3-400 id say turbo brand new will cost about 3k personally i woudlnt even bother doing a top swap id turbo. you can make double the power of a supercharged setup
  17. #17 Re: add on supercharger
    Jun 2011
    How many times do i need to say this...
    TURBO
  18. #18 Re: add on supercharger
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by lilmidge12 View Post
    you can 9.4, people have done it, probly need a bigger cam though
    i like the m90 but...........
    air to air intercooler ftw
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  19. #19 Re: add on supercharger
    antioch ill
    TURBO
    dan how many times do we gotta tell you ​new tips
  20. #20 Re: add on supercharger
    Kansas
    Especially when alot is spelled a lot.
  1. Supercharger bearings shot!:o no more supercharger?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2011, 02:27 PM
  2. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  3. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  4. supercharger
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 07:30 PM
