Thread: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearings
Results 1 to 16 of 16
  1. #1 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearings
    Jan 2013
    flint mi
    im new to this I,m in the process of putting a 160000 mi motor in my gtp my ? is should i put rod bearings in it while its out of the car seance i know its the rod bearings that go bad
    in the first place the engine runs great its in a roll over that I bought its all hwy mi and why do they blow the rods in the first place any help would be appreciated
  2. #2 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    If you took the bottom end apart, it must see a machine shop or else it will be a 10 mile motor.
    Just throw the motor in and hope for the best really, no one can say how long it will last.
  3. #3 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    flint mi
    so I guessing what some other ppl told me u just cant put rod bearings in it will have to go to the machine shop for that
  4. #4 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    You could do the bearings yourself, its just that the block needs machine work before anything can go back together.
  5. #5 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  6. #6 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    i work in a machine shop,
    if you were to swap just the bearings, while measuring nothing, it will probly work fine.
    if you were to just bolt the engine in the car and turn the key, it will probly work fine.
    new bearings will still vary as much as a .001 new out of the box. that may help you, or it may fuk you over
    if your not going to have the rods resized then dont bother with the bearings
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  7. #7 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by fox66669 View Post
    its not so much the bearings that go bad, its the rods/rod bolt
  8. #8 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Quote Originally Posted by Seachicken View Post
    I take it you havent rebuilt a 3800 from the ground up before.
    Just slapping some new bearings in it without machine shop work on the block will just blow it up.
  9. #9 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    Edmonton, Alberta
  10. #10 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    Edmonton, Alberta
    fox6669: so I guessing what some other ppl told me u just cant put rod bearings in it will have to go to the machine shop for that
    what are you going to machine on the block that has any relevence to changeing rod bearings??
  11. #11 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    GT Level Member Toms04compg's Avatar
    Michigan
    If it helps I spun bearing 6 and 2 and 3 were lapped if I recon. I had my crank cut .010 and polished so as per cut you have to get the correct size rb's and mob.I also had my oil pump rebuilt with touch hone cylinder walls with new piston rings. A new balance and key way was my decision. That cost me about 200 in parts from rockauto.com as for the block work it was done by a machine shop and then assembled by my guy. But what I can say is all the rest head ... gaskets and drop in was done by me. I've driven it for 6300 miles since then and it is fresh to death. Total labor and parts cost me 650$ as I dropped just the block off in the first place so no tearing down was necessary
    I do stand my that as a good rebuild and necessary means to have it done right IMO.hope that helps. As to why rb's get spun is most likely bad maintenance .. crappy oil and weight ...and abuse hope that helps.
  12. #12 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    the block NEEDS to be aligned honed for the crank. these blocks twist a bit.
  13. #13 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    Edmonton, Alberta
    yes it does, but that deals with the main line (main bearings) , i thought we were talking about the ROD bearings
    a line hone matters none to the rod bearings
  14. #14 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Thats the problem with buying a used engine, you dont know how well it was taken care of by the previous owner and you don't know how long it will last. It could last for the rest of the life of the car, it could last 3 days you never know.
  15. #15 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    it all should be done. the price to have it done and add new bearings, and bolts dont compare to a used block. or justify the price to just "freshen up" a engine. this is why most just find a good used block to deal with.
    if it was a sbc 350, you could just slap new bearings in all day and it would have a good chance of running good for a long time.<< if just to re fresh it.
    of course anytime you blow a rod or main bearing shop work will be needed regardless of what engine it is.
    to the OP, the 160,000 mile motor, do a compression test on the cylinders, if they all have good compression drop it in. also check the lim gaskets, if plastic change them, do that before you drop it in if needed.
    these engines if maintained run well over 200,000. and that just means changing the oil regularly really. every 3 to 5,000 miles. your choice. i buy oil on sale, and change it every 3,000 miles. runs me 25 bucks tops with a filter. money well spent.
  16. #16 Re: 98gtp100,000 on body bad engine swap q on 160000 mi motor ? about engine bearing
    Jan 2013
    Edmonton, Alberta
    its just as much a crap shoot for a 350, as it is a 3800, if you dont measure, you dont know
    but listen to scotty, dont fix whats not broke, resealing the top now well serve you better the doing a "mechanics rebuild"
  1. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  2. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  3. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  4. Motor Problems or Engine Swap?
    By sharp in forum General Tech Discussion
    Last Post: 06-20-2010, 06:16 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
