Thread: 1998 pontiac grand prix gt wont start
Results 1 to 10 of 10
  1. #1 1998 pontiac grand prix gt wont start
    Jan 2013
    il
    i did a intake gasket swap and put everything back the way it should it sat for three weeks but still wont start any ideas? it has new spark plugs, new spark plug wires, and new coils.
  2. #2 Re: 1998 pontiac grand prix gt wont start
    did it run after you finished the gaskets?
    could be a broken vac line.
  3. #3 Re: 1998 pontiac grand prix gt wont start
    Jan 2013
    il
    no it didnt i just finushed put it all back together and there was one plug that had a extention that doesnt plug into anything around where it is
  4. #4 Re: 1998 pontiac grand prix gt wont start
    some cars have a extra plug off the rear of the engine. so if your sure everything is plugged in, it should be ok.
    start with the basics, check for fuel and spark.
  5. #5 Re: 1998 pontiac grand prix gt wont start
    Jan 2013
    il
    it has fuel and spark but it start sputs and the wont stay on and then it back fired then wouldnt start after that it hasnt been started in over 3 weeks
  6. #6 Re: 1998 pontiac grand prix gt wont start
    double check your plug wires.
  7. #7 Re: 1998 pontiac grand prix gt wont start
    Jan 2013
    il
    they are in the right order would it change if it wasnt supercharged?
  8. #8 Re: 1998 pontiac grand prix gt wont start
    its the same.
    if its popping and back firing, thats a usually some sort of ignition problem. icm could be bad or something like that. still a chance yo left something unhooked too. i can only assume it ran ok before you tore it apart.
  9. #9 Re: 1998 pontiac grand prix gt wont start
    Check the connections at the ICM and MAF as well as the one by the coil packs that connects your crank sensor/cam sensor to the PCM and ICM
  10. #10 Re: 1998 pontiac grand prix gt wont start
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  1. 1998 Pontiac Grand Prix won't start
    By Dogman1969 in forum General Tech Discussion
    Last Post: 11-03-2012, 12:28 PM
  2. 1995 pontiac grand prix turning over but wont start.. help!
    By kdf401 in forum General Tech Discussion
    Last Post: 10-12-2012, 07:09 PM
  3. 1998 Grand Prix Heated Seats Wont Turn Off
    By njfelix0712 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:35 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. 1998 grand prix GT wont crank
    By li0nhe4rtt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2010, 04:23 AM
