Thread: 'Sup- Noob sorta.
Results 1 to 14 of 14
  1. #1 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    New to the forum but not to Grand Prix. Owned and '83 back in the day. Was glad to see that rust bucket go. Picked up an '06 Base a week ago for my daughter but need to fix er up first. Some minor issues since it's already got 146k on it. Wish the link for the CEL codes would work!
  2. #2 Re: 'Sup- Noob sorta.
    Apr 2012
    Goderich, Ontario
  3. #3 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    Thanks Smoke. I know what my code is, just don't know what to do with it. P2340
  4. #4 Re: 'Sup- Noob sorta.
    Code P2340 does not come up on alldata, you sure thats right?
  5. #5 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    Crap. I meant P2430. (I have a bumper sticker that says "Dyslexic if you're Honk!")
  6. #6 Re: 'Sup- Noob sorta.
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    you put the same number...
  7. #7 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    98buicksupercharged- Now who's dyslexic?
  8. #8 Re: 'Sup- Noob sorta.
    No he didnt.
    P2430 is a secondary air injection problem.
    P2430 Secondary Air Injection System Pressure Sensor Stuck In Range - With Automatic Transmission
    Possible Causes Setting Conditions
    • AIR pressure sensor connector is damaged (check pins for damage, moisture)
    • AIR pressure sensor signal circuit is open
    • AIR pressure sensor signal circuit is shorted to ground or shorted to voltage
    • AIR pressure sensor reference circuit is open
    • AIR pressure sensor low reference circuit is open
    • AIR control/shut-off valve assembly has failed
    • ECM has failed
  9. #9 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    So, where is this elusive Secondary Air Injection System Air Flow/Pressure Sensor Circuit? My manual hasn't arrived yet.
  10. #10 Re: 'Sup- Noob sorta.
  11. #11 Re: 'Sup- Noob sorta.
    Nov 2012
    Madison
    might help
  12. #12 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    Quote Originally Posted by spazzz View Post
    might help
    Video! Now that's more my speed. Thanks spazzzz. I'll try that this weekend. Looking forward to that damn little engine light to stop mocking me.
  13. #13 Re: 'Sup- Noob sorta.
    Jan 2013
    Charleston, SC
    might help[/QUOTE]
    Well strike one. My Grand Prix is nothing like the car in this video. The fuse for the air pump is 50 amp, (and not blown) AND I just popped out both headlights and no pump tucked into the fender where the video shows. Any other suggestions guys?
    Edit-It's hard to see it, but it appears that I have an actual pump, driven by the serpentine belt. Is that possible?
    My Haynes manual is worthless.
    Edit- FOUND IT. It's in the engine compartment right under the air filter box about a mile and a half down. Hard as hell to get to. Yes, it's electric, full of water, and corroded. Takes a suction of air right out of the air intake, so yes, dumb-a$$ GM Engineers.... it will suck in water too! There's another $100 to stick in the black hole. Any opinions on which brand to buy or avoid?
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    If I remember right it's in the front bumper cover in front of the left wheel usually water fill up in the pump and causes a short and blows the fuse. The the fuse if its blown that's most likely your problem. Take the left side splash shield off and pull the lower hose off the pump usually water will come running out. In the cold they will freeze and bust also
  1. Car stalls SORTA?!
    By Tino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2012, 11:37 PM
  2. I'm backkkkk, well, sorta...
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 05-17-2011, 05:35 PM
  3. Dora the hood rat *sorta nws*
    By 99prixgt in forum Off Topic Discussion
    Last Post: 03-20-2011, 06:59 PM
  4. Got rid of the tri spokes...sorta
    By Sandman in forum Tires & Wheels
    Last Post: 02-07-2010, 04:48 PM
  5. New to everything...sorta!!
    By c32k05 in forum Introductions/Noob Questions
    Last Post: 04-23-2009, 03:22 PM
