he would be referring to the air intake tube from the air box, where the air filter is, you need to take the tube off, its clamped to the TB. its a hose clamp. you will need a set of security torx bits, 5 or 6 bucks for a cheap set at the parts store. to remove most of the sensors. you want to remove your MAF sensor, the one on top of the TB because spraying anything but maf cleaner on the MAF will kill it.
