Rather than blinding oncoming traffic with HID plug and play kits, get decent bulbs (silverstars, ZXE, Luminics...) then build a relay harness. wire the relay harness so that when you turn on your lowbeams the facatory headlight plug turns on a relay and runs power straight from the battery to new plugs that are plugged into your bulbs. I have found that stock wiring has a lot of resistance and you lose voltage. for example, on my 95 Jimmy I had 11.3 volts or so at my headlight plugs. Once I built the Relay harness I had 14.4 volts at the new headlight plugs. with Silverstar Ultras my ligt output was still controlled and non-blinding to oncoming traffic, pure white rather than the dingy amber most halogen lights are, and bright! they were brighter than my Highbeams. but the beam pattern was still controlled by the reflector so there was no glare. Just a thought... 5 bucks for a relay, 10 bucks for the new plugs, and wire... Most of us probably have wire in our garages...
