Thread: which cantuned pcm can be tuned after install?
Results 1 to 20 of 31
  1. #1 Re: which cantuned pcm can be tuned after install?
    3.2 is too small of pulley to start with.
    At a warmed up idle in Park, ign adv should be around 22 if I recall correctly.
    Ign Adv will always jump around with throttle %, so those numbers are moving around.
    P0420 is a cat code and being that you're 01+, that screws up alot of numbers and how the computer thinks.
  2. #2 Re: which cantuned pcm can be tuned after install?
    Nov 2012
    earth
    http://www.grandprixforums.net/remov...know-7092.html ---->p0420 code?
    Idle voltage 0.47 vdc I'm guessing it's getting it's signal from tps. The voltage signal tracks linear positive without any drops with steady accel, or holding at any particular position.
    Warmed up in park is 27* 0* kr....... 1/16 throttle in gear crusing 37* 0*kr.... then immediate, back well below 20* anything over 1/2 pedal
    starts fine, possible cam gear? chain tensioner?
    thanks
  3. #3 Re: which cantuned pcm can be tuned after install?
    Nov 2012
    earth
    How much impact is the computer seeing with 2 dtc of fan circut 1 and 2 fail with p0420?
  1. Which tuned ECM for an 05 GTP?
    By ls1freek in forum PCM Tuning
    Last Post: 10-20-2011, 02:59 PM
  2. Do I need a tuned PCM.
    By Jbruce in forum PCM Tuning
    Last Post: 07-30-2011, 06:36 AM
  3. Is my PCM tuned already?
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 01-29-2011, 07:18 PM
  4. Help me with a Tuned PCM!
    By extreme in forum 04+ Specifics
    Last Post: 02-04-2010, 07:29 PM
