Thread: How do I fix coolant sensor?
Results 1 to 19 of 19
  1. #1 Re: How do I fix coolant sensor?
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    heres a link to get to it. and what it looks like. looks like a 50 dollar part. 2002 Pontiac Grand Prix Problem Bad Low Coolant Sensor Engine Cooling 6 Cyl
    and doing your own brake is about the easiest thing ever. with new pads and rotors, about a 100 bucks.
    heres a vid, after the wheels off its a 4 bolt job. you dont need to take off the brake line. that stays on. you will need a brake tool to close the piston on your year car i think, it needs to twist back into the caliper. this guy changed the calipers as well, not needed in your case.
    Thank you! Do I have to touch the brake lines at all?
    I just found the sensor for $23 at advance auto parts
  2. #2 Re: How do I fix coolant sensor?
    Quote Originally Posted by Jtiger360 View Post
    Not need to touch the brake lines. Just push the caliper piston back in and install the pads and rotors.
    And from a shops point of view, 255 is a good deal on new brakes for the rear. Shop pays 50-70 for all the parts, they mark it up to make money and then go off book time for a rear brake job, which is just about 1 hour, so shop labor is 100/hr. It all adds up.
  1. coolant temp sensor
    By billyt in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2014, 12:19 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  4. coolant sensor
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 12-30-2009, 07:56 PM
  5. Low Coolant light - bad sensor?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2008, 08:19 AM
