Thread: Oil Leak/Light Seepage
Results 1 to 12 of 12
  1. #1 Re: Oil Leak/Light Seepage
    Tell us which gaskets they plan to replace. Because even if they swap out an oil pan gasket, you might still have seepage if it's the rear engine cover gasket (common). And to do the rear engine cover gasket....yeah..you have to pull the engine or trans.
  2. #2 Re: Oil Leak/Light Seepage
    Nov 2012
    Las Vegas
    Ouch! That repair -- coupled with the others I have had to do -- would cost more than I bought the car for. Curiously, I am not seeing any oil leakage when I park the car on a level road, but when I park it in my driveway, which is on an incline, there are noticeable drips. d
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
