Thread: Valve Cover gasket leak
Results 1 to 7 of 7
  1. #1 Valve Cover gasket leak
    Oct 2012
    Floyds Knobs, Indiana
    Hi. I am hoping to find enough info to help me tackle the job of replacing the valve cover gaskets on my wife's 2005 gtp.
    I am new at doing things under the hood. But have been successful with wheel bearing assembly replacement so I am getting
    more confidence. There seems to be lots of great info here. Thanks, Kevin
  2. #2 Re: Valve Cover gasket leak
    GT Level Member Toms04compg's Avatar
    Michigan
    Its easy just some spots its hard to get to, move anything thats in your way. Take the dog bones off in front if you need more clearence. Check out our how to section. Or the search link. Im sure if there isnt a exact how to on valve cover replace look at push rods replace and valve cover has to be removed to get to that.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Do a search, this has been very well covered many times.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  4. #4 Re: Valve Cover gasket leak
    Sep 2011
    Copperas Cove, TEXAS
    Welcome to GPF and the wonderful world of leaky valve cover gaskets. Use the search, it helps.
  5. #5 Re: Valve Cover gasket leak
    Oct 2012
    Wow...thanks to you all for the replies. I will take all of your advise and study the valve cover project using the search feature.
    I am sure I can do this with such great help on this forum.
    Thanks again from Floyds Knobs in southern Indiana!
  6. #6 Re: Valve Cover gasket leak
    Where do you live in IN?
  7. #7 Re: Valve Cover gasket leak
    Sep 2011
    Your Welcome Guy.
  1. Valve Cover Gasket?
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 09-10-2012, 08:20 AM
  2. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  3. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  4. Help with Valve cover leak
    By gwizlo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 09:24 AM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
