Thread: Transmission Match Ups
Results 1 to 6 of 6
  1. #1 Transmission Match Ups
    Oct 2012
    Beacon, NY
    Hi everyone, I own a 2002 Pontiac Grand Prix SE and I want to swap out the 3.1L LG6 V6 (mine says 3100 SFI V6. Not sure if they're the same engine or not) with a 3.8L 3800 Series 2. I want to know If I should get the 3.8L S/C because I plan on putting a turbocharger in it or if I should just get the 3.8L with no S/C? My main goal is to up the engine to a 3.8L because many of my friends say the 3.1L wouldn't be able to handle a turbo (they mostly deal with Civics) and I want to up my 4-speed auto to a 5 or 6 speed auto but I can't find out what 5 or 6 speed automatic transmissions match up with the 3.8L engines. Which leads to my main question, what type of 5 or 6 speed trannys can I use with the 3.8 that won't potentially get ruined and cost me in end? (If I can even up my tranny to a 5 or 6 speed.) Please let me know my fellow Pontiac drivers and mechanics.
    P.S. I know very little about cars and I'm learning on the way.
    - Matthew Mericle
  2. #2 Re: Transmission Match Ups
    You cant use a 5-6 speed trans as they make anything that can even be controlled via our PCM.
    You best bet is to find a GT or GTP motor with trans, the wire harness, PCM and everything else needed to make the swap and then it might work.
  3. #3 Re: Transmission Match Ups
    Oct 2012
    Beacon, NY
    Ok thanks. Also would you know why my 02 GP overheats while idle? I flushed my radiator, put new tubes, both fans are on while parked and I still can't figure it out. It also says low coolant buti put new coolant in. could it be because my ac doesn't kick on? I forgot what the part was called.
  4. #4 Re: Transmission Match Ups
    You probably need to bleed the cooling system of air.
  5. #5 Re: Transmission Match Ups
    Oct 2012
    Beacon, NY
    I also think I need a new radiator because when I take the cap off I have built up rust and it's still happening after a radiator flush. Plus my abs light stays on constantly even after I put my new hubs on.
  6. #6 Re: Transmission Match Ups
    Your lower intake manifolds gasket its probably leaking. Have your abs code scanned could be abs module bad.
  1. trans match up
    By cliffdawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2012, 09:03 PM
  2. My Dupli-Color Fix..how I got to match
    By BlackGT97 in forum Visual/Body Modifications
    Last Post: 07-02-2012, 09:21 PM
  3. Speedo & HUD don't match
    By Whitephxaz in forum General Tech Discussion
    Last Post: 08-13-2011, 03:55 PM
  4. duplicolor-perfect match
    By dpzelenak in forum Off Topic Discussion
    Last Post: 05-08-2011, 12:34 PM
  5. color match
    By Tha Ghost in forum Visual/Body Modifications
    Last Post: 01-04-2011, 04:32 PM
