Thread: Correct temp??
Results 1 to 10 of 10
  1. #1 Re: Correct temp??
    flush the heater core, by removing the hoses off the engine, then flush it with a garden hose.
    then fill the rad wait for the engine cooling fans to come, this can take a while as you already found out, 15 to 20 minutes easy. now on top of your t stat housing is a bleeder screw, when the fans come on, you know the t stat has opened, now open the screw a few turns till a solid stream of coolant comes out., shut screw top of the rad. and that should do it. i leave the cap off the whole time while its warming up, if coolant burps out, let it, its normal. when the t stat opens the level should in the rad should drop. top off as needed.
  2. #2 Re: Correct temp??
    Oct 2012
    illinois
    Great thanks for the advise on both issues. I'd have regretted it big time if I had gotten the grinder out and cut those off. I think maybe soundfx mufflers or some other options would be wiser. Now to fix that fuel sender so I can tell how much go juice I got.
  1. Intake temp vs coolant temp.
    By chicagochuck in forum General Tech Discussion
    Last Post: 09-30-2012, 08:44 PM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  4. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  5. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
