Thread: Transmission jerks when car gets warm
Results 1 to 6 of 6
  1. #1 Transmission jerks when car gets warm
    Oct 2012
    Hello my 97 grand prix gtp has recently started jerking and shifting a little hard through every gear after about 30 to 45 mins of driving. Other than that it shifts fine. Can anyone tell me what is going on with it? Is it a censor or something? My engine light has not come on at all during this. Any suggestions or help would be greatly appreciated!
  2. #2 Re: Transmission jerks when car gets warm
    St. Louis
    You won't get a CEL for this. Most likely if you have it scanned for trans. codes by a higher end scanner than you find a Autozone you will find that the PCS (pressure control solenoid) is commanding max pressure. Take a quick search through the 4T65E forum and see what you can find.
  3. #3 Re: Transmission jerks when car gets warm
    what kinda of miles you got, it could just need a filter and fluid change. clogged filters dont work well. can cause low line pressure and stuff.
    hows your fluid look? is it red? or dark and burnt smelling? trans ever been serviced as far as you know?
  4. #4 Re: Transmission jerks when car gets warm
    Once it gives you a harsh shift. Drive to an Autozone etc that can scan it. Do not turn the ignition off. (a buddy in the car helps) then have it read.
    The code for P1811 should be current.
  5. #5 Re: Transmission jerks when car gets warm
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  6. #6 Re: Transmission jerks when car gets warm
    Mar 2013
    tazewell
    did u ever figure out what was wrong with it mine is doing the same thing shifting hard when it gets warm.
  1. trans jerks after stop
    By grey08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2012, 08:45 PM
  2. My car jerks at 4000 RPM/ Shuts off when I reverse
    By metalexa1 in forum Introductions/Noob Questions
    Last Post: 06-08-2012, 03:26 PM
  3. 2004 GTP COMP G warm weather transmission problem?
    By Kodiak19 in forum General Tech Discussion
    Last Post: 07-26-2011, 02:11 PM
  4. NEED HELP: Speedometer malfunction and car jerks
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-11-2010, 08:39 PM
  5. jerks when shifting
    By kenneth74gt in forum General Tech Discussion
    Last Post: 01-04-2009, 01:23 PM
