Thread: Timing Belt Noise Question
Results 1 to 1 of 1
Threaded View
  1. #1 Timing Belt Noise Question
    Oct 2012
    TimbuckToo
    i have a 1994 Grand Prix GTP 3.4 dohc, and i had the timing belt, tensioner pulley, idler pulleys and tensioner replaced and everything sounded fine for a week. I took the car back to have the oil pump shaft seal replaced which entailed pulling the back cams and head to replace the o-ring, and ever since i get the car back when you start the car you can hear a weird grinding noise coming from the worked on section. you can hear the noise here: https://dl.dropbox.com/u/3065306/201...2021.02.25.mov (it takes 15 sec's or so to start streaming) and also when you pull the inspection covers off the belt is WAAAY too tight it has no roll in it what soever. Any thoughts on what to look for?
  1. 95 Grand Prix GTP timing belt question
    By Kathy Collins Ives in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-25-2012, 07:02 AM
  2. 1995 Grand Prix GTP ! Timing belt question
    By Rockhound in forum General Tech Discussion
    Last Post: 05-15-2011, 08:47 PM
  3. timing belt
    By DunriteDiesel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2010, 12:38 PM
  4. Timing belt swap
    By Ryan D. in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-03-2010, 04:54 PM
  5. Timing Belt
    By Doerr in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-05-2009, 11:01 AM
