Thread: water pump blew?
Results 1 to 14 of 14
  1. #1 water pump blew?
    SE Level Member GPgal91's Avatar
    Sep 2012
    Canada
    K so I'm pretty sure my water pump just blew, there is coolant everywhere i can't seen to find any broken hoses or anything i filled the reservoir with water and ram the car to see if i could find where the leak was coming from but no luck. Any way to tell for sure if this was just my water pump that blew, or another problem having to do with my cooling system?
  2. #2 Re: water pump blew?
    SWPA
    Might be coolant elbow that let go.
  3. #3 Re: water pump blew?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    did you notice symptoms in the days before it went? My went a couple weeks ago. Starting a couple days earlier, i heard what sounded like bad bearings and had a belt chirp when accelerating hard. I guess it was partly seized and revving the engine slid the belt across the pulley. It had also been running hotter than usual but not quite in the red zone(once it went, it did overheat briefly until i found a safe place to park.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  4. #4 Re: water pump blew?
    take the belt off and grab the w/p pulley, see if it has side to side play, if so its shot.
    if your losing coolant fast. id think one of the coolant elbows blew out. you have 2 if your a 99 or newer car, the 2 nd one is hiding behind the water pump
    see right above the power steering pump and behind the water pump that tube that turns in, this is a 98 so its a cast elbow, 99 and up has another plastic elbow there, as well as the one at the top of the pic.
  5. #5 Re: water pump blew?
    Sep 2012
    Canada
    K ya no significant signs before it went its bin making some weird noses lately knocking, now that its gone to its squealing really bad
  6. #6 Re: water pump blew?
    SWPA
    The squeeling may be a wet belt. The coolant elbow may have had a small leak beforehand. My lower elbow was seeping just right for it to land on the belt and the belt slung coolant everywhere.
  7. #7 Re: water pump blew?
    Sep 2012
    Canada
    K so i just went out and looked again and moved a few things around and found the leak, right underneath the pulley
  8. #8 Re: water pump blew?
    that would be the water pump. now take the belt off and see if the w/p pulley has play in it, if so you need a new pump for sure.
    if your supercharged, you need a T55 bit to remove the lower sc idler pulley. and you need to un bolt the power steering pump as well.
    this is the pump off, the p/s pump unbolted and the lower idler removed.
    i also took the fuse box off and tied it off to the side for more room. if your overflow tank is right there remove that too.
    and the only tips you should need is to loosen up the 4 small bolts on the w/p pulley before you take the belt off, or you will never get them off, same thing when you are done put the belt back on and tighten up the 4 bolts. and to clean and put thread sealant on the 4 long bolts for the water pump, as they enter the block, coolant will come out when you take the bolts out.
    the power steering pump is bolted on with 2 bolts, in the 12 and 6 positions, there is a hole in the pulley, use a 3 inch extension and a socket.
    that idler and the p/s pump need to come off to get the 4 long bolts off.
  9. #9 Re: water pump blew?
    Sep 2012
    Canada
    Ok thank you for you're help guys
  10. #10 Re: water pump blew?
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  11. #11 Re: water pump blew?
    Sep 2012
    Canada
    All fixed, Thank you
  12. #12 Re: water pump blew?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    this is my ex she has my old gp it was the water pump
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  13. #13 Re: water pump blew?
    nudes? lol
  14. #14 Re: water pump blew?
    mass
    Gutta love those elbows going through the tensioner.
    Tony
    1aauto.com
    SALES 888-844-3393
  1. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  2. Water pump HELP
    By cincygoat in forum Off Topic Discussion
    Last Post: 06-26-2011, 06:57 PM
  3. water pump
    By fatty13 in forum General Tech Discussion
    Last Post: 03-15-2011, 09:40 PM
  4. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  5. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
