damn. check your vaccum lines again. check LT and ST fuel trims, or again if you already did. if it drives fine otherwise you know your hard parts that were replaced during the rebuild.. the pcm is seeing something happen it doesnt like at wot. it doesnt set any codes at idle or normal driving does it?
