Thread: engine troubles
Results 1 to 8 of 8
  1. #1 engine troubles
    May 2012
    michigan
    I have a 2004 grand prix series 3 3.8 L non supercharged gt2 does anyone know if this engine is prone for failing I'm on my 2nd engine just started the dreaded rod knock first engine did the same thing 1st engine had 130k 2nd 70k engine was installed by certified mechanic. I'm not hard on my car and I change my oil and I don't use penzoil what the heck is going on
  2. #2 Re: engine troubles
    Bad luck?
    These motors are very stong and will last a very long time.
    Maybe both these motor saw some coolant in the oil?
    Its so hard to say, but I'm it does suck when another motor dies.
  3. #3 Re: engine troubles
    It's not common for the motors to puke like that. Any known reasons why they died?
  4. #4 Re: engine troubles
    May 2012
    michigan
    No coolant in the oil at the time of failure. I'm searching for answers. Has anyone blown up 2 3800's in a month with normal driving
  5. #5 Re: engine troubles
    I've seen it... but haven't necessarily come to an answer with stock programming and stock motors.
  6. #6 Re: engine troubles
    May 2012
    michigan
    Well I just talked with a guy that used to machine these engines and when pontiac started to go down hill they changed their machine tool life from 1500 to when their tooling broke so parts for this engine that were machined after 2002 were not the most precision parts being put together. They had some engines fail on the way to the parking lot after assembly so maybe I just got 2 of these junk engines
  7. #7 Re: engine troubles
    GTP Level Member 1ATony's Avatar
    mass
    welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  8. #8 Re: engine troubles
    May 2012
    michigan
    Thank you. I'm looking for a place to get a Reman. Anyone have any places in mind?
  1. Top Swap Troubles??
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 09:39 PM
  2. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
  3. having troubles with load on engine
    By tonydtech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2009, 03:44 PM
  4. Electrical Troubles
    By Orozco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 12:00 AM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
