Physically felt and inspected the back of the Headlight Switch and it is in good shape with no signs of heat or burns. I do, however, have an aftermarket set of headlights with Halo rings and such but have had NO issues with that. Maybe this might be the issue but there is no heating issue and all the bulbs work fine when working. I will replace with OEM headlights to see if this is the culprit and then look again at the BCM. Also, my inspection did not pass due to the Computer not being able to be read. (Another tell tale sign of BCM?)
