Thread: still working on ABS issue
Results 1 to 5 of 5
  1. #1 still working on ABS issue
    Nov 2008
    Bend, Oregon
    Hi, read a couple threads on ABS issues, My 04 GTP flairs up every now and then. I will try some dilectric on the fuses and hub conecctions.
  2. #2 Re: still working on ABS issue
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Quote Originally Posted by stumper View Post
    have you looked for any damaged or chaffed wiring? what about your hub bearing assembly? how does it look?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: still working on ABS issue
    Nov 2008
    Bend, Oregon
    Quote Originally Posted by TEK310 View Post
    replaced r front hub bearing assembly and still had same issue, issue is abs will cycle/activate brake (chatter sound), sometimes with this chatter the no traction control lite on dash lites up, sometimes the ABS service lite on center reader board lites up, this will happen several times a week or just a couple times a month, no real pattern. gone to auto parts shops and plug into scanner and guy just says ABS needs service. been doing this for several years now, started shortly after a warrenty engine swap at 27000 miles, changed hub around 70000, now has 90000
  4. #4 Re: still working on ABS issue
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    not sure if you've fixed it but it may be a short, open or low voltage to one or all abs sensors. check for a loose connections and/or faulty/damaged sensor. Remember, it only takes one fault in the system to set the ABS light
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  5. #5 Re: still working on ABS issue
    Nov 2008
    Bend, Oregon
    Will try to look at it this weekend, sold the car to my daughter, hard to lock her down for service, buzy girl
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  3. A/C not working
    By NewPrixOwner666 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:30 PM
  4. working on an stalling issue
    By alexo1us in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2009, 05:56 PM
  5. New transmission not working correct - possible PCM issue?
    By knightmastery in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2008, 05:13 AM
