Thread: 2005 Grand Prix Comp G GTP... no heat coming from heater/ almost over heating.. HELP
Results 1 to 4 of 4
  1. #1 2005 Grand Prix Comp G GTP... no heat coming from heater/ almost over heating.. HELP
    SE Level Member Rileys05GTP's Avatar
    Sioux City Iowa
    Hey I got a 2005 Comp G GTP with 70,500 miles on it, just recently the car started to get just under overheating on the gauge and the heater wont blow hot. Thought it may be a thermostat so changed that and it didn't help the temp gauge then just started moving and would still get just under overheating with no hot heat. So I took the car to my mechanic and he found that the water pump was bad so changed that. Still did not fix the issue. So then took the engine apart assuming maybe a bad head gasket or bad head. Had the heads sent into a auto shot and the heads are in perfect condition and didn't even need cleaned up. Really puzzled with what this problem could be were putting the engine back together tomorrow with new head gaskets.
    If anyone has any ideas please let me know!! Thanks
  2. #2 Re: 2005 Grand Prix Comp G GTP... no heat coming from heater/ almost over heating.. H
    Kansas
    Wow, even took the heads off. Just an FYI these head gaskets are pretty stout, and don't tend to give out very often. Are you losing any coolant by chance when you check the radiator? Have you ever flushed the radiator? Dex tends to crud up when mixed with green antifreeze. Maybe the previous owner put green in with Dex? Heater core maybe clogged?
  3. #3 Re: 2005 Grand Prix Comp G GTP... no heat coming from heater/ almost over heating.. H
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  4. #4 Re: 2005 Grand Prix Comp G GTP... no heat coming from heater/ almost over heating.. H
    Sioux City Iowa
    im gonna try to flush the radiator when the engine gets put back together...hopin it works!
  1. FS: 2005 Pontiac Grand Prix GTP Comp G
    By rocket69GTP in forum For Sale - Vehicles
    Last Post: 09-25-2016, 09:18 AM
  2. 2005 Grand Prix GTP Comp G
    By speedy2 in forum Members Rides
    Last Post: 02-15-2012, 10:28 PM
  3. no heat coming out of heater
    By jharry83 in forum General Tech Discussion
    Last Post: 03-19-2011, 09:57 AM
  4. 2005 Grand Prix GTP Heater Core
    By silver05gtp in forum General Tech Discussion
    Last Post: 12-01-2010, 02:48 PM
  5. 2005 Grand Prix heater inlet hose?
    By xctment in forum General Tech Discussion
    Last Post: 01-17-2009, 08:43 PM
