Thread: Trouble with my Blower Fan for 2001 GTP.
Results 1 to 3 of 3
  1. #1 Trouble with my Blower Fan for 2001 GTP.
    Jan 2012
    North Andover, MA
    Hey guys, I'm new here... I have a 2001 GTP with a blower fan that does not work. I've checked the fuses and they're fine. I've learned that it could be the resister but that's just a maybe. So here are my problems.
    1. How can I check the resister to see if it is working properly and also do I have to remove the fan itself to check the resister?
    2. what is the best way to get at the blower fan?, ie. where is it and how do I get to it?
    3. I've read about a chip that says I'll get 10% better MPG & 20-40 more HP. This sounds to good to be true. Has anyone here ever installed one of these and what were your results?
    Thanks very much for any responses!!!
  2. #2 Re: Trouble with my Blower Fan for 2001 GTP.
    The chip is a scam.
    The blower motor is under the passenger side dash. Pull the kick panel, then it's three screws. Once you pull the blower, likely it's rusted. There's a thread about a water deflector...that someone soon will link for you. Hope that fixes ya up.
  3. #3 Re: Trouble with my Blower Fan for 2001 GTP.
    SE Level Member TheManInBlack's Avatar
    Dec 2011
    Detroit, Michcigan
    I know you can test the blower once you pull it by hooking it up to your battery, if it doesnt turn on its bad..
  1. Heater blower trouble ....
    By matt1long in forum General W body
    Last Post: 05-06-2016, 07:54 PM
  2. 2001 GTP SE Front Fender same as 2001 GT
    By BrentHamm in forum Visual/Body Modifications
    Last Post: 12-19-2011, 05:22 PM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. 2001 no blower
    By Dstahl5555 in forum General Tech Discussion
    Last Post: 04-26-2009, 10:56 PM
