Thread: Sunroof Issue.
Results 1 to 3 of 3
  1. #1 Sunroof Issue.
    Oct 2011
    Fort Wayne
    I bought my Grand Prix about four months ago and about a week and a half after I bought it my sunroof decides not to slide all the way back anymore (it worked fine up until then, was just a little slow at opening and closing), and progressively stopped going further and further back. Now it will only slightly pop up about a quarter of an inch if that. The drive side of the sunroof seems to be the root cause of the issue. For awhile it wouldn't shut all the way down but the passenger side would. If anyone knows anything about what could be the problem help would be greatly appreciated. Also, on a side note. My AC/Heater only works on 5 (the highest setting), but it does blow out cold and hot air could it be the relay that's bad?
  2. #2 Re: Sunroof Issue.
    Omaha, NE
    The sensor that senses opening and closing is probably bad in the sunroof.
    Welcome to GPF.
  3. #3 Re: Sunroof Issue.
    Oct 2011
    Fort Wayne
    Thanks man, Ill give that a shot, is it expensive to fix?
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. Tip: Sunroof issue fix 04+
    By Explicit_Spade in forum How To Write-Ups/Tech Tips
    Last Post: 02-19-2011, 07:11 PM
  3. Sunroof
    By zildjian102 in forum Visual/Body Modifications
    Last Post: 10-23-2010, 06:26 AM
  4. sunroof
    By kpowell in forum General Tech Discussion
    Last Post: 04-09-2010, 12:53 PM
  5. Sunroof
    By SuperCharged0nE in forum Visual/Body Modifications
    Last Post: 11-22-2009, 09:59 PM
