Thread: draining the fuel tank
Results 1 to 5 of 5
  1. #1 draining the fuel tank
    Jul 2011
    Honolulu
    I had my 2001 Grand prix in storage for 3 years. Now I need to drain the fuel tank. A siphon hose does not get into the tank. So how does one empty the tank?
  2. #2 Re: draining the fuel tank
    go in the trunk and pull the carpet up and in the middle should be a panel you can unbolt and under that is the fuel pump, take the pump out and suck the fuel out and then put the pump back in.
  3. #3 Re: draining the fuel tank
    Jul 2011
    Honolulu
    Thanks, I give it a try.
  4. #4 Re: draining the fuel tank
    Jul 2011
    Honolulu
    To drain the fuel tank, we tried disconnecting the fuel line at the filter. But we only got about a gallon out. I saw somewhere that jumping the fuel-relay pins 30 & 87 would "hot wire" the fuel pump. But that did not work.
  5. #5 Re: draining the fuel tank
    you need to take the pump out.
    there are 2 connectors that you unplug on the top of the pump and 3 lines. 1 for the fuel line, 1 for the return and 1 for the evap. remove those and use a snap ring pliers to remove the snap ring and then pull the pump out.
  1. Drop Fuel Tank
    By roundbox52 in forum General Tech Discussion
    Last Post: 07-15-2023, 08:43 PM
  2. Fuel Tank Sensor going bad
    By GAFF in forum General Tech Discussion
    Last Post: 04-04-2011, 09:40 PM
  3. change fuel tank, now no start
    By nypilot21 in forum General Tech Discussion
    Last Post: 08-02-2010, 12:10 PM
  4. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
  5. fuel tank capicity
    By whiteknuckle in forum General Tech Discussion
    Last Post: 01-19-2009, 07:44 PM
