Thread: E-brake light wont turn off need help!!
Results 1 to 7 of 7
  1. #1 E-brake light wont turn off need help!!
    Jul 2011
    minneapolis
    my e-brake wont turn off need help!!!
  2. #2 Re: E-brake light wont turn off need help!!
    Waukesha, WI
    check the wire and plunger under the dash by the arm ? it might be stuck down
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: E-brake light wont turn off need help!!
    does the grand prix brake light say e brake or just brake like my regal? if so you could just need brake fluid. maybe check the master cylinder fluid level.
  4. #4 Re: E-brake light wont turn off need help!!
    SWPA
    This.
    The BRAKE light in the dash isn't just to tell you the ebrake is on, its to tell you the fluid is low
  5. #5 Re: E-brake light wont turn off need help!!
    Jul 2011
    minneapolis
    i checked the the brake fluid its full...
    redlinepontiac : can you explain more about the this wire can be ??
  6. #6 Re: E-brake light wont turn off need help!!
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    brake lines ****in up
  7. #7 Re: E-brake light wont turn off need help!!
    Check the fluid level, sensor on the side of the MC res is plugged in and that the pedal is all the way up on the ebrake.
  1. e-brake light wont turn off
    By basballny2 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 04:07 PM
  2. brake lights, cigarette lighter, turn signal wont work
    By dlouis30 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:31 AM
  3. Brake light, turn signal, cigarette lighter wont work
    By dlouis30 in forum Introductions/Noob Questions
    Last Post: 03-02-2010, 10:07 PM
  4. Glove box light wont turn off?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 10-27-2009, 06:32 PM
  5. Tire Pressure light wont turn off.
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-25-2009, 10:40 AM
