Thread: Bad ignition switch? any help is apreciated
Results 1 to 10 of 10
  1. #1 Re: Bad ignition switch? any help is apreciated
    May 2011
    portland
    Well from every other site I have read on a battery dieing like that is a ignition switch but deffinatly not a gear head I haven't had the battery tested yet but will do soon the key comes out fine and rotates all the way over it does the same thing I have seen a lot of people deal with where the key gets locked and you have to push the button under the steering column to release it but has done that for years now
  2. #2 Re: Bad ignition switch? any help is apreciated
    when you jump start it, is the whole car dead? no horn or windows working? if the whole cars dead, check out the batt and the alt.
  3. #3 Re: Bad ignition switch? any help is apreciated
    May 2011
    portland
    Yeah when I have had to jump it everythings dead no power locks or anything like that so battery and alt will be checked first
  4. #4 Re: Bad ignition switch? any help is apreciated
    May 2011
    portland
    Checked the battery today at 2 different auto parts stores both if them came out good battery ...alt next?
  5. #5 Re: Bad ignition switch? any help is apreciated
    out of all the different ways to test a battery and/or an alternator, the one i think is best is the kind that you clip onto the battery, and it reads the volts, that test where the battery is, then you start the car and re read the tester, and that reading is the alt voltage. if its charging at 13 or to 14 is good, any lower than a 12.7 and its toast.
    every time i remove the alt and take it to be tested, they are wrong, brand new tested good 2 times, and it was bad, a good one i had tested bad, autozone sucks a big one and pep boys aint to far behind.
  1. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  2. ignition switch
    By mtz956 in forum General Tech Discussion
    Last Post: 08-10-2010, 04:53 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
