Thread: cylinder #3 misfiring
Results 1 to 5 of 5
  1. #1 cylinder #3 misfiring
    SE Level Member pontiacGTP1999's Avatar
    PA
    I have a 1999 grandprix gtp 3800 supercharged, it recently developed a REALLY bad miss and i can hardly get it outta my driveway. the check engine lite can on so i had it put on a computer that checks the codes (not sure what codes came up) but it said that theres a misfire on cylinder #3. does anyone have any ideas to what it would be? any suggestions would be appreciated! and just to let all of u know that has a 3800 w/ a supercharger, there is oil in them and it is to b changed from time to time. i didnt know anything about this until i was lookin on the net and if u google it u will find how to change it and where to find the place to change it!
  2. #2 Re: cylinder #3 misfiring
    Houston
    Pull the spark plug in cylinder 3 and inspect it. And check the post on the coil labeled 3 for corrosion.
  3. #3 Re: cylinder #3 misfiring
    PA
    just took my car to the garage so we will c what the verdict is. Keith it didnt look like ther was any thing on the wire but i didnt pull it off to look throughly.
  4. #4 Re: cylinder #3 misfiring
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Some possible troublemakers are: fuel injector, coil, plug, plug wire, ICM, and PCM. I guess a bad LIM could also be a cause, but probably not. I recently had some misfire issues myself and a new ICM and PCM fixed it.
    I don't think that the supercharger lacking an oil change would cause a single cylinder misfire.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: cylinder #3 misfiring
    Houston
    I was talking about pulling the plug wire from the #3 coil located below. I had a some misfires on #5 and the post on the coil had some corrosion. I cleaned it off and that was that.
  1. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  2. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  3. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  4. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
