Thread: GXP Transmission Question?????
Results 1 to 8 of 8
  1. #1 GXP Transmission Question?????
    St. Louis
    Recently my 06 GXP trans has been acting up. 1st, 2nd, 3rd are great and perform just fine. Problem is somewhere in 4th at around 65-70mph it will jump in rpm's from 1800 up to abt 2300 and back down again. Just today while accelerating to pass on the highway it stayed in 4th and shuttered pretty bad. Fluid is 5000 miles old. Did complete flush (including converter) and replace filter and gasket. Used DEX 6 Valvoline full Synthetic. Any one else had these problem??
  2. #2 Re: GXP Transmission Question?????
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    how much fluid did you put in it? and you check the dipstick to see if you lost any?
    and welcome to the forum!
    <MiZzBeCcA>its not rape if you yell suprise
  3. #3 Re: GXP Transmission Question?????
    St. Louis
    I unfortunaley didnt do it personally. I have a good friend that runs a shop here in STL and I purchased 14 quarts based on what he told me his machine required. I know if you just drain the fluid and not the converter its only 7.4 quarts. I check the fluids weekly because of the mileage I drive and it is perfect everytime in the last 5000 since the change. I'm clueless...
  4. #4 Re: GXP Transmission Question?????
    May 2008
    staten island,NY
    my old trans did that when the converter was going bad
  5. #5 Re: GXP Transmission Question?????
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    i never flush mine. just drop the pan and change the fluid and filter. just me cuz im a cheapo
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  6. #6 Re: GXP Transmission Question?????
    St. Louis
    Sorry I've got transmission on the brain right now. Thanks for the welcome and I appreciate any advice or info.
  7. #7 Re: GXP Transmission Question?????
    Feb 2010
    indianapolis
    does sound like the converter is dropping out of lockup and slipping when in lockup. get ahold of trippleedgeperformance.com and that the man you need to talk to.
  8. #8 Re: GXP Transmission Question?????
    St. Louis
    I checked it out. Thanks for the info. Has anyone done business with him before?
  1. transmission question
    By rmplow in forum General Tech Discussion
    Last Post: 12-26-2010, 07:51 PM
  2. Transmission, question
    By overdrive in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-09-2010, 11:02 PM
  3. Transmission question if anyone can help!!
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2010, 10:39 PM
  4. Transmission question
    By dearmond in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2009, 03:11 PM
  5. question about my transmission
    By 01prixse in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-27-2009, 05:00 AM
