Thread: Popping Sounds When Turning?
Results 1 to 18 of 18
ljmonnin12 Popping Sounds When Turning? 11-15-2010, 06:48 PM
kfish Re: Popping Sounds When... 11-15-2010, 07:06 PM
machinegunsquid Re: Popping Sounds When... 11-15-2010, 07:21 PM
lambokit Re: Popping Sounds When... 11-15-2010, 07:52 PM
ljmonnin12 Re: Popping Sounds When... 11-15-2010, 08:53 PM
ljmonnin12 Re: Popping Sounds When... 11-15-2010, 08:56 PM
busmech Re: Popping Sounds When... 11-15-2010, 09:17 PM
ljmonnin12 Re: Popping Sounds When... 11-15-2010, 09:20 PM
busmech Re: Popping Sounds When... 11-15-2010, 09:27 PM
gtptim Re: Popping Sounds When... 11-16-2010, 04:23 AM
ZR1Vette09 Re: Popping Sounds When... 11-16-2010, 12:39 PM
machinegunsquid Re: Popping Sounds When... 11-16-2010, 02:28 PM
ZR1Vette09 Re: Popping Sounds When... 11-16-2010, 03:00 PM
ljmonnin12 Re: Popping Sounds When... 12-18-2010, 01:16 AM
JoshsGTP Re: Popping Sounds When... 12-18-2010, 03:17 AM
biggt Re: Popping Sounds When... 12-18-2010, 04:53 AM
TheOtherNick Re: Popping Sounds When... 12-18-2010, 11:59 AM
itNEEDSwork Re: Popping Sounds When... 05-06-2011, 09:05 AM
  1. #1 Popping Sounds When Turning?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    I have a 1997 Pontiac Grand Prix GT and I've owned it for about a year now and whenever I make a turn I hear popping sounds coming from the front of the car. Anybody have a clue what this might be?
  2. #2 Re: Popping Sounds When Turning?
    Donating Users kfish's Avatar
    Ohio
    strut mounts.
  3. #3 Re: Popping Sounds When Turning?
    Florida
    Or half shafts... Does it get faster the faster you go through the turn? and does it get worse the harder you turn??? Annnddd....does it do it on both sides??
    Im putting my money on your half shafts (FWD drive-shafts)
  4. #4 Re: Popping Sounds When Turning?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    X2^ sounds like a CV joint. Axle.
    Lambokit to be built!!!!!
  5. #5 Re: Popping Sounds When Turning?
    Nov 2010
    Sidney, OH
    I notice it a lot when I'm backing up while I'm turning. Not so much when I'm turning while I'm driving 20+ mph, but it does it a little bit while I'm driving 20+ mph. More when I'm going slow basically.
  6. #6 Re: Popping Sounds When Turning?
    Nov 2010
    Sidney, OH
    Oh, and are any of these things that can possibly be wrong really expensive?
  7. #7 Re: Popping Sounds When Turning?
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    Sounds like CV joints...when your backing up the speed is low enough to allow them to click...at higher speed in forward motion the weight of the car prolly keeps them from clicking as noticebly..yes they are sort of spendy if you cant do them yourself..good luck...
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  8. #8 Re: Popping Sounds When Turning?
    Nov 2010
    Sidney, OH
    Does this harm the car if not fixed a.s.a.p?
    -ljmonnin12
  9. #9 Re: Popping Sounds When Turning?
    Apr 2009
    Minneapolis MN
    I wouldnt put it off too long...they can break almost any time and create mayhem w/the rest of your drivetrain...not worth the risk IMO..
  10. #10 Re: Popping Sounds When Turning?
    Lima, OH
    I had a popping like that before when i would turn the wheel and when i would go over a bump it turned out to be a broken sway bar. Mine was broken right at the sway bar link!
    1/8mile: 9.354sec@77.026mph the best 60ft: 2.211sec
    1/4mile: 14.2889sec@93.16mph the best 60ft: 1.9668sec
  11. #11 Re: Popping Sounds When Turning?
    MO
    Quote Originally Posted by gtptim View Post
    http://www.grandprixforums.net/signa...les-31603.html <- please read. thanks.
    I agree, sounds to me like cv joints. Simple enough to do.
    <brandonl2000> LMAO D!!
  12. #12 Re: Popping Sounds When Turning?
    Florida
    Yeah, basically when the CV joint in the Axle goes bad, it clicks/pops like hell when turning, the sharper the turn, the louder/harsher the click/pop. It's pretty easy to replace, and they arent tooo expensive..
    Think I spent about $150 for both at Advance Auto Parts, and they are lifetime warrenty.
  13. #13 Re: Popping Sounds When Turning?
    MO
    Plus some tranny fluid... 20 bucks a bottle?
  14. #14 Re: Popping Sounds When Turning?
    Nov 2010
    Sidney, OH
    Not to bring this all up again... But I brought my car to my mechanic and had him listen to the popping and he said it's normal and cars do that. Idk what to think. I had my tires off and was looking and the CV axle and stuff and I didn't see anything out of the ordinary wrong with it. What are visual signs something like that's going bad?
    -ljmonnin12
  15. #15 Re: Popping Sounds When Turning?
    Akron Ohio
    Check your lower contol arm bushings
  16. #16 Re: Popping Sounds When Turning?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    im having the same popping and its my strut mount
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  17. #17 Re: Popping Sounds When Turning?
    Charles City, IA
    Strut mount, broken coil spring, or worn rack bushings.
    SMGPFC Two Nipple General
  18. #18 Re: Popping Sounds When Turning?
    May 2011
    Buffalo, NY
    I've had that same noise and I found that my spring had snapped. This is pretty simple to fix as long as u have a COMPRESSION TOOL !! Without this tool u have a very hard time trying to compress the spring enough. I found that the tool is only about 14$ and is key to replacing the spring!
  1. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  2. Wheel Popping in and out
    By 2000GrandPrixGTP in forum General Tech Discussion
    Last Post: 06-26-2010, 03:37 PM
  3. Popping In Reverse
    By Chmanzi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2010, 11:00 PM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
