Thread: What should my first mod be ?
Results 1 to 20 of 41
  1. #1 Re: What should my first mod be ?
    Willoughby, Ohio
    agreed intake is the first mod, along with flipping your dogbone mounts since its free
    also read this
    http://www.grandprixforums.net/new-m...ads-36503.html
  2. #2 Re: What should my first mod be ?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    intake!
    Quote Originally Posted by CTKGP09 View Post
    also read this
    what does fliping your dog bones give you?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  3. #3 Re: What should my first mod be ?
    I live here. TLSheff's Avatar
    9000hp instantely
    j/k http://www.grandprixforums.net/dog-bone-flip-13286.html
    Quote Originally Posted by Abrasive View Post
    You basically turn this....
    Into this....
    I do it just as Scimmia described, by removing the torque strut (dogbone) from in between the part pictured above and the engine brackets just to get it completely out of the way. Then with the bracket still attached to the car, put the bolt back through the bushing and tighten down the nut completely. Then I take a flat screwdriver and pry the rubber bushing back just enough to spray some lubricant in behind it all the way around. A little WD-40 works good. Then I put a 15mm wrench on the bolt head and another on the nut that I just put back through the rubber bushing and begin pushing the two wrenches towards the engine. Turn them slowly to make sure you are not tearing the bushing and sometimes you have to work them back and forth a little bit to get the entire bushing to "flip" 90 degrees. Once finished, the bushing is now solid on the front and back which is where the engine puts the most force against them as it tries to move back and forth. Then just take the nut off and remove the bolt, reinstall your dogbones, and you're done.
  4. #4 Re: What should my first mod be ?
    Becca Boo MizzBecca's Avatar
    Michigan
    Quote Originally Posted by tlsheff View Post
    no thats the performance ebay computer chip. Duhhhhhhhh.
    I drive a POS
  5. #5 Re: What should my first mod be ?
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Buy a turbo and go pick on some vettes
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
