Thread: Head Gasket Repair
Results 1 to 7 of 7
  1. #1 Head Gasket Repair
    SE Level Member routzahn06gtp's Avatar
    attica,IN
    im needing some step by step instructions on how to change my head gaskets. any help would be appreciated>
  2. #2 Re: Head Gasket Repair
    Akron Ohio
  3. #3 Re: Head Gasket Repair
    attica,IN
    what is this man??
  4. #4 Re: Head Gasket Repair
    Akron Ohio
    it will tell you everything and anything you need to know.
  5. #5 Re: Head Gasket Repair
    attica,IN
    so i have to buy the program to use it? anyone else be able to help me out with some instructions
  6. #6 Re: Head Gasket Repair
    Akron Ohio
    Have you tried looking aroung in the how to section?
  7. #7 Re: Head Gasket Repair
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    REMOVAL: removing everything from engine is common sense. Remove anything that bolts to the heads. Remove the heads( start at outside bolts and work your way in a cross pattern. spray some carb cleaner or gasket remover on block deck (makes it easier to remove gasket material) and scrape off old gasket material with a gasket scraper. careful not to scratch block though. make sure you remove all of old gasket or new gasket wont seal right. get heads resurfaced if you have to. TO INSTALL: MAKE SURE BLOCK IS DRY AND CLEAN. Place new gasket on block. It normally says which side faces up and Front means its on the harmonic balancer side and lower head onto block. it self aligns due to dowel pins on block. you need new head bolts since they are tty. install bolts and tighten them hand tight. use torque wrench to torque bolts to i think 37 ft/lbs if i'm not mistaken in 3 increments. (15, 25, 37ft/lbs in sequence. then an additional 120 degrees to each bolt in sequence. Rocker arm bolts torqued to 11ft/lbs. then an additional 45-90 degrees. they are tty too but its up to you if you want to get new ones. as far as order or sequence, you can either turn crank where both valves on each piston are closed ( pushrod is at bottom if its travel) and tighten two bolts at a time or just tighten them all at once but make sure the rockers full seat on the bracket. then scrape off old silicone from intake and use silicone on water ports on heads and install new intake gaskets and apply silicone on gaskets where water ports are at. seat intake and tighten bolts not too tight though just enough where your wrist does the torqueing. everything else is pretty much straight forward. hope this helps
  1. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  2. Water vapor in exhaust after LIM gasket repair
    By Obrigado in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-26-2010, 08:12 AM
  3. Hello.1999 2nd intake gasket repair
    By tgoepfert in forum Introductions/Noob Questions
    Last Post: 02-08-2010, 08:59 PM
  4. Intake Gasket Repair
    By lg8806 in forum General Tech Discussion
    Last Post: 12-13-2009, 01:35 AM
  5. So.......Is it a head gasket
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-22-2009, 04:58 PM
