Thread: computer problem
Results 1 to 6 of 6
  1. #1 computer problem
    Feb 2010
    grand rapids mi
    i did the intake on my gtp power washed the hole moter i think i might have got the computer wet because i have no power now my lights flash and battery light came on when i flore it it barly goes and the gage in the center of the car that tells gas milage oil useage while work fin then when i start it up it goes dim and heads up display stops working could this be a computer problem every thing worked fine untile i power washed the car
  2. #2 Re: computer problem
    Topeka, KS
    This is why when you wash the motor you use the mist like spot free wash instead of the full boar wash. Electrical + Water = BAD. Check all of your fuses, grounds, and battery connections.
  3. #3 Re: computer problem
    there are gaskets on the PCM connectors that shouldn't be leaking.
  4. #4 Re: computer problem
    Feb 2010
    grand rapids mi
    w got a new computer prograhmed it and still the same problem evereything works fine with the ignitionon the on position but as soon as i start it heads up dispay goes on and off also the infermation board light go out and as soon as i hit the gas the lights flash. car also will barly move
  5. #5 Re: computer problem
    Feb 2010
    grand rapids mi
    i figured it out i feel dumb it was the altinator it started puting out 18v on an ideal and would clime alot higher when moveing
  6. #6 Re: computer problem
    regulator was ****ED if it did that.
  1. Wrong Computer?
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2010, 09:57 PM
  2. CAI and the computer
    By BigTom73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 07:57 PM
  3. computer help
    By gtpinsc in forum Off Topic Discussion
    Last Post: 10-21-2009, 09:49 PM
  4. Computer Upgrade!!!
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-14-2008, 01:14 PM
  5. Need Computer Help
    Last Post: 04-06-2008, 11:58 PM
