Thread: Code P1655
Results 1 to 3 of 3
  1. #1 Code P1655
    Kansas
    Hey guys I have a 1996 Grand Prix with a 3.1 the check engine light is on. The code is P1655 how do you go by fixing that problem
  2. #2 Re: Code P1655
    Kansas
    can anyone fix the P1655 code
  3. #3 Re: Code P1655
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    p1655: evap purge valve/solenoid. i'd call the gm dealership and consult them. ive read its a dealer specific check engine code.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  1. does anyone know how to fix this code?
    By shsfootball57 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 12:33 PM
  2. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  3. p0121 code
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2010, 10:13 PM
  4. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
