Thread: Lim gasket
Results 1 to 4 of 4
  1. #1 Lim gasket
    SE Level Member cardiffGIANT98gtp's Avatar
    Kansas
    what all will i need to an LIM job
  2. #2 Re: Lim gasket
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I just replaced mine. U will need basic tools. Wrench, sockets, extensions, ect. Also u will atleast need some knowledge on how 2 work on a vehicle. U have 2 remove the fuel rails, supercharger, intake, injectors, wires, and remember how it all goes back. Bad thing is that alot of the little plastic vacuum hoses can break and need 2 be replaced. Also make sure everything is clean b4 putting on the new gaskets. When u put the intake manifold back on u need 2 follow a certain bolt pattern when reinstalling it, if not u can break the intake manifold, i suggest get u a haynes manual from advance auto or somethin, it helped me.
  3. #3 Re: Lim gasket
    Kansas
    I did it a couple weeks ago, but thanks.
    Everything worked out real good except now i've noticed that i'm loosen coolant somehow. There's no puddles under the car, everything on the motor looks dry, i replaced all the elbows and o-rings, and there's no water in the oil so i'm stumped at the moment. My only other guess is that it leaks while i'm going down the road.
  4. #4 Re: Lim gasket
    GEORGIA
    check all the freeze plugs on the block and every hose possible, its coming out of somewhere.
  1. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  2. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
  3. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
  4. SC Gasket Swap
    By Darkcelle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 03:45 PM
  5. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
