Thread: Need help wiring amp
Results 1 to 4 of 4
  1. #1 Re: Need help wiring amp
    GT Level Member tmackster's Avatar
    San Antonio, TX
    wrong place to post a thread about wiring instruction...post this under tech tips or general tech discussion to get a quicker response!..
    '06 GP GT // Debadged // 20" Niche Venice rims w/toyo proxes4 tires, ram air inferno hood, front air dam, SE rear valance, black l.e.d. tail lights, CAI, MSD Ignition wires, Pioneer 6x9, & 10,000K HID headlights!!!
  2. #2 Re: Need help wiring amp
    GT Level Member skidoojames151's Avatar
    seattle
    alright this car is super easy to do.lift up the carpet in the passenger footwell where the carpet ends, you will find a rubber grommet with alot of wires goin through ittake the rectangle grommet out and then get ur wire through there.i wired my amp through the center console and under the back seat and through the bottom of the back seat door
  3. #3 Re: Need help wiring amp
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by skidoojames151 View Post
    but when U find that hole with the rubber boot u'll have to stick a screw driver in there to wiggle it to stretch the rubber so ur ( guessing ) 4gauge wire can fit. I started with engine and went into passenger firewall ( more near middle of car ). peeled carpet back and ran thru the middle console, under the carpet to under the rear seat. good luck and welcome.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
  2. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  3. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  4. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
  5. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
