Thread: Hello from Ohio
Results 1 to 8 of 8
  1. #1 Hello from Ohio
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Hello All!
    I got my 2000 Grand Prix GT new in 2000, but was forced to hand it over to the wife 3 years ago when she needed a practical sedan to drive. It just rolled 100,000 miles and is in need of some work. I've been lurking here for a few weeks getting tons of info...thank you!! I am right now in the middle of replacing the water pump, thermostat (180degree sounds like the recommended) lower intake manifold gaskets, valve cover gaskets, coolant elbows. She had some leaks...coolant and oil. I'm hoping to get the engine running well, and then on to some body work. I've had this car for 9 years and its still fun to drive. Again, thank you all for the info posted here...without it, I would have been lost.
  2. #2 Re: Hello from Ohio
    TDCRacing
    Guest
    Welcome to the community
  3. #3 Re: Hello from Ohio
    GTP Level Member dstout's Avatar
    ky
    Hello, no need to lurk, got lot of good info here.
  4. #4 Re: Hello from Ohio
    Oct 2008
    mascoutah, Il
    Welcome! good luck with the repairs
    2002 GTP
    custom HOK paint
  5. #5 Re: Hello from Ohio
    GT Level Member chad27's Avatar
    Apr 2009
    gpt,ms
    Welcome
    1.0 pcm upgrade, comp cam, zex 50 shot, msd 8.5mm wires, copper plugs side gap, head work comp springs, all fluids mobile one
  6. #6 Re: Hello from Ohio
    Toledo, Ohio
    Thanks everyone! Hope to post some pic's of the job, soon. Getting my waterpump on Thursday. I reassembled the intake manifold with a new GM aluminum gasket and a new plenum gasket too. The intake manifold cleaned up good, and looks great. New coolant elbows on...too.
  7. #7 Re: Hello from Ohio
    Ohio
    welcome fellow ohioan. good luck w/ the projects
    00 GTP demodded and forsale
  8. #8 Re: Hello from Ohio
    Edmon, OK
    Hello Everyone!
  1. Hello from Ohio
    By TZ250 in forum Introductions/Noob Questions
    Last Post: 07-15-2009, 10:41 AM
  2. newb from Ohio
    By TheGreatestFall in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:37 PM
  3. Hello from Ohio
    By slaminsammy1 in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:33 PM
  4. Another Ohio guy
    By bobsgtp2nv in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:25 PM
