Thread: what front passenger brake line do i get?
Results 1 to 4 of 4
  1. #1 what front passenger brake line do i get?
    Aug 2021
    ohio
    I have a 1999 Pontiac grand prix GT with four wheel disk brakes. I purchased the car for next to nothing because it needed the front passenger side brake line replaced. I thought that would be no big deal but appearantly not because there are multiple different brake lines that all are listed as being the correct one for my car. I want to know that the correct line should look like so I don't buy the wrong one.
  2. #2 Re: what front passenger brake line do i get?
    St. Louis
    Are you talking about the rubber line that goes to the caliper or the steel line that goes from the ABS unit to the pass. side and then connects to the rubber line?
  3. #3 Re: what front passenger brake line do i get?
    Aug 2021
    ohio
    its the steel part that connects to the rubber piece that goes the the caliper. if it helps the popped line is right above the power steering rack.
  4. #4 Re: what front passenger brake line do i get?
    Mar 2018
    NY
    I would call your local GM dealer with the vin and get a part number from them then you can at least cross reference something
  1. Front Passanger brake line
    By rvnwlf in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2014, 10:23 AM
  2. front brake line question
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2013, 03:01 PM
  3. Replacing brake line - ABS module to right front wheel
    By SPECIAL EDITION in forum General Tech Discussion
    Last Post: 10-31-2011, 03:51 PM
  4. ss front brake line
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 03:08 AM
  5. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
