Thread: GT to GTP Swap
Results 1 to 2 of 2
  1. #1 GT to GTP Swap
    Apr 2019
    Cleveland
    i have a regular 2002 3.8 gt. i’ve decided its time for a new one as my body is falling apart and the frame is trash, so i found a 2002 gtp 40th anniversary in great condition with a bad motor. how hard would a swap be to put the supercharger on my regular 3.8?
  2. #2 Re: GT to GTP Swap
    depends on what went bad on the sc engine, if it chipped a piston the head is pooched, or a blown rod can hurt the head too. if it was over heated bad, could have cracked a head.
    you need the heads, lim and blower and all the sc belt accessories, balancer idler tensioner. and new head bolts. or buy studs, bolts are way cheaper tho. while the engines apart and out of the car, clean it and re gasket everything. good time to paint it as well if you care to.
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  3. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
