Thread: 1995 GrandPrix GTP charging circuit voltage drops when Engine warms up
Results 1 to 3 of 3
VBChevy 1995 GrandPrix GTP charging... 03-30-2019, 06:17 PM
Fivefingerdeathpunch Re: 1995 GrandPrix GTP... 03-31-2019, 12:00 AM
VBChevy Re: 1995 GrandPrix GTP... 03-31-2019, 09:53 AM
  1. #1 1995 GrandPrix GTP charging circuit voltage drops when Engine warms up
    Mar 2019
    Virginia Beach
    Hey everyone. New here and I figured you all may be able to assist with my Issue,
    My 95 GTP charging voltage drops when the engine warms up. 3.4 liter "X" motor. I have heard that it is a bad design with the Alternator right beside the exhaust manifold with a thin heat-shield.
    I read 14.7 volts across the battery with the engine running cold when first started. When warmed up voltage drops to 12.3 which is battery voltage. I had the battery put under load and it checked fine.
    Wanted to see if I may be missing something before I get into replacing it, which I am not looking forward to, after reading the R&R instructions.
    Anybody else have or have had this issue?
    Thanks in Advance
  2. #2 Re: 1995 GrandPrix GTP charging circuit voltage drops when Engine warms up
    The internal voltage regulator could be failing when it gets hot. I'd been looking at a replacement as well.
    Never done one before but youtube for some video's to see if you find anyone that has.
  3. #3 Re: 1995 GrandPrix GTP charging circuit voltage drops when Engine warms up
    Mar 2019
    Virginia Beach
    This is the R&R steps according to the manual. Looks like a project. May have to get an estimate. The car only has 82K miles, so I guess it depends on how much I want to keep the car. A youtube video on this would be a movie.
    1995 GrandPrix GTP charging circuit voltage drops when Engine warms up Attached Images
  1. Replies: 4
    Last Post: 11-03-2011, 08:03 AM
  2. P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    By WonBadGTP in forum General Tech Discussion
    Last Post: 02-14-2011, 08:41 AM
  3. Car Shuts Off When Engine Warms Up
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-23-2010, 04:22 PM
  4. underhood relay center/ voltage to fuel circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-06-2009, 05:10 PM
  5. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
