Thread: Battery overcharging with 3 month old battery
Results 1 to 6 of 6
  1. #1 Battery overcharging with 3 month old battery
    Nov 2018
    Canada
    I have a 2006 Grand prix base model with a new battery I put in back in November. Intermittently the car simply will not turn over, so I get it boosted, the car is fine for a while, then it won't start again...rinse and repeat. Today I put a battery tester on the battery and it showed 12.7 volts not running and 16 volts running. The battery is being overcharged obviously, but why? and how can I test to see if its the voltage regulator or something else.
  2. Dislikes Scottydoggs disliked this post
  3. #2 Re: Battery overcharging with 3 month old battery
    the alt could be bad. ive had 2 in a row rebuilt's for a truck i owned over charge, truck hated it too. so much it told me so on the DIC lol
  4. #3 Re: Battery overcharging with 3 month old battery
    volts don't start a car... amps do. While you appear to be having a volt issue, what do the amps say?
  5. Thanks LouF thanked for this post
    Likes LouF liked this post
  6. #4 Re: Battery overcharging with 3 month old battery
    Feb 2019
    CT
    You have a kind of scatter shot mess of information here. A car that won't turn over isn't always a low battery, it could just be a bad connection at the battery, or a bad starter, or a bad connection at the starter..
    Next time it won't turn over, check your battery voltage directly at the posts. If its anywhere above 12.2, its just a loose connection or bad starter.
    When the battery is low, the alternator will put out more voltage, at least the one in my truck does this when i leave it parked for several days.
    Then when the battery is well charged, the charging voltage drops to ~14V
    So in your case, intermittent charging (or possibly a constant load drawing down the battery when it is parked) puts the battery in a weak state and the alternator pumps out more juice to bring the battery back.
    If you have a charger, Charge the battery up well, then re-test the alternator charging voltage.
    THe battery reading @ 12.7 is fully charged..
    EdIT:
    3 month old battery means this has probably been an ongoing issue? or maybe the battery change created the problem?
    Either way, often times batteries go dead because the alternator is on its way out.
    the old alternator in my truck had deep grooves worn in the contact rings and brushes that were worn too short to make full time contact.
    I would notice my headlights going from normal brightness to dim randomly when parked with my headlights pointed at a wall
  7. #5 Re: Battery overcharging with 3 month old battery
    Nov 2018
    Canada
    Thanks guys for the responses, I'm 90% sure now that all this trouble is caused simply by bad battery connections, but there is a but!!! With the engine running I put a battery tester on the posts it shows only 12.7v, when I put the tester on the connectors it show 14.7, BUT...as the Battery tester stays on the connectors the volts slowly go up past 15v towards 16v, which is why I initially asked about the battery overcharging. My question is would the alternator put out more volts than normal 14.7 because there is a bad or no connection to the battery posts??
  8. Thanks LouF thanked for this post
  9. #6 Re: Battery overcharging with 3 month old battery
    Feb 2019
    CT
    if you are reading 12.7 at the posts with the engine running but 14+ at the connectors, yes, you have bad connections.
    remove connections and clean up mating surfaces with a battery terminal cleaner brush. Clean battery posts too.
    butter both up with a dielectric grease (I've also seen white lithium grease used)
    reconnect and retest
    report back here
  1. Dead battery, no amp draw and battery tests fine
    By pontiac98 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2016, 09:44 PM
  2. New Battery, New Alternator, Battery still dies. Any Ideas?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 03-19-2015, 10:05 PM
  3. Battery help
    By mikejohnlewis in forum General Grand Prix Discussion
    Last Post: 03-05-2015, 03:51 PM
  4. Where should I get my battery
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-25-2011, 01:05 PM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
