Thread: Heater question 2006 Grand Prix
Results 1 to 4 of 4
  1. #1 Heater question 2006 Grand Prix
    Nov 2017
    Girard KS
    Ok i have a 2006 Grand Prix i just bought it and when i bought it i was told it had a bad heater core which it indeed was bad/ leaking. So i changed it and had heat for one ride in the car after that and then there was no heat just slightly warm air. I replace the thermostat after and bled the coolant system but still no heat. I took it to get the codes read/cleared and as i was driving it back to the house i hit a bump and i had heat blowing until i got home and put it in park. Again i have had no heat since. My opinion is that
    A. I have a loose wire somewhere.
    B. I have a bad solenoid somewhere. (But as this is my first Grand Prix and my first front wheel drive car i don't know much.)
    C. One of my motors are shorting out.
    If anyone on here has run into something like this and could give me some pointers it would be much appreciated.
  2. #2 Re: Heater question 2006 Grand Prix
    St. Louis
    Are both the heater hoses hot going to the core? Check the wiring to the blower motor itself. Should be up under the dash. The wiring may be melted and causing an intermittent connection.
  3. #3 Re: Heater question 2006 Grand Prix
    Nov 2017
    Girard KS
    Both the hoses are hot and i will give that a shot
  4. #4 Re: Heater question 2006 Grand Prix
    Oct 2011
    Toledo, OH
    Sounds like blend door is sticking.
    7"
  1. 2006 Grand Prix question
    By SilverGPGT06 in forum Introductions/Noob Questions
    Last Post: 04-06-2015, 07:20 PM
  2. 2006 Grand Prix. Sway Bar Bushing Question.
    By 2prixxx in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2014, 07:22 AM
  3. 2006 grand prix gt supercharged audio question
    By dman2kx in forum How To Write-Ups/Tech Tips
    Last Post: 02-17-2014, 11:24 PM
  4. 2006 Pontiac Grand Prix GT Window Tinting.. serious question here.
    By crumbut in forum General Tech Discussion
    Last Post: 05-07-2010, 01:16 PM
