Thread: New here with a GTP that won't start... sometimes.
Results 1 to 12 of 12
  1. #1 New here with a GTP that won't start... sometimes.
    Oct 2017
    GA
    I've got a 2000 GTP. Completely stock, very clean. 60k miles on it. Inherited from my grandfather.
    Just joined the forum to research common problems. Every once in a while it refuses to start... fuel pump will prime, just nothing from the starter. I was thinking it could be an ignition switch or a NSS. Like I said just joined to search out common problems so I have a starting point.
  2. #2 Re: New here with a GTP that won't start... sometimes.
    Clean all battery connections, grounds etc on the battery, body and starter first.
    That's the free thing to do, then past that it could be the ignition switch or something related to that.
  3. #3 Re: New here with a GTP that won't start... sometimes.
    Aug 2016
    MN
    Next time it does that try shifting into neutral and starting. If it starts then it's probably the nss.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  4. #4 Re: New here with a GTP that won't start... sometimes.
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Also next time it doesn't start try holding the key in the start position and the tilt lever with the other hand and move the column up and down.
    I was helping a friend with a 97 and had an intermittant start issue like this. I checked the starter and battery wiring and all was good. Then tried moving the column and it started. Shortly after he sold it so never figured out what exactly it was.
  5. #5 Re: New here with a GTP that won't start... sometimes.
    Oct 2017
    GA
    Yeah done that
    Quote Originally Posted by Mitch R View Post
    Tried that, but from my understanding it can still not start in neutral with a bad NSS sometimes. (Depending on how the switch fails?)
    Quote Originally Posted by green97 View Post
    Good idea.
    So weird, it just started after not starting for 2 days. It was parked in my job's parking lot so I couldn't really do any diagnosing on it. Called a tow truck and it started right before the truck got there... grrr. Hard to diagnose the issue when the issue is gone. I tried jiggling wires around hoping to bring the issue back, no dice. Guess I'll just have to wait till next time it rolls around.
    Key turned, nothing. Usually you'll get some indication the starter is trying to work (clicking or lights dimming) but it's just like nobody's home.
  6. #6 Re: New here with a GTP that won't start... sometimes.
    Jul 2016
    St. Louis
    It could be a bad spot on the Starter. I had one do this to me before. Starts fine and then all of a sudden nothing. Has full power with everything else, just no start. I took it off and brought it to a friend who rebuilds starters and alternators, he took it apart and sure enough it had a bad spot that whenever it stopped at that point, the next time it wouldn't start.
  7. #7 Re: New here with a GTP that won't start... sometimes.
    Oct 2017
    GA
    Quote Originally Posted by waupachino View Post
    So I think I figured it out.
    It was a combination of issues.
    Car wouldn't start again this morning. Heck yeah, could finally take a meter to it and start diagnosing.
    No voltage going to starter.....
    Checked out the fuse box. Found a bad connection at one of the fuses... fixed it...
    Voltage at starter now when turning key, still nothing... had someone hit it with a wrench while I turned the key... bam, started right up. Bad starter.
  8. #8 Re: New here with a GTP that won't start... sometimes.
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    To diagnose the last bad started I swapped, I had the luxury of hitting the remote start while I was under it , ready to give it a thump. Amazing how some things respond to the "Fonzarelli Touch" ... lol. .... Wait, how old are you??....lol.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  9. #9 Re: New here with a GTP that won't start... sometimes.
    aaaaaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyy
  10. #10 Re: New here with a GTP that won't start... sometimes.
    May 2016
    Rouge Island
    Twolf's profile shows he's 22. He might get it?
  11. #11 Re: New here with a GTP that won't start... sometimes.
    Oct 2017
    GA
    A little early for my time... lol
  12. #12 Re: New here with a GTP that won't start... sometimes.
    next time you find your self with nothing to do or watch, google happy days, its corny looking back, but at the time the fonz was the sh it.
    even as a little kid i always wondered why anyone would be scared of old spaghetti arms there.
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. Installing remote start on non-remote start car
    By GPmanter in forum General Grand Prix Discussion
    Last Post: 01-29-2016, 11:39 AM
  3. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  4. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  5. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
