Thread: 2003 3.1, ac control panel
Results 1 to 2 of 2
decifal 2003 3.1, ac control panel 08-27-2017, 12:18 PM
wstefan20 Re: 2003 3.1, ac control panel 08-28-2017, 05:18 PM
  1. #1 2003 3.1, ac control panel
    Apr 2013
    Dickson, TN
    Hello, i'm having issues with my current control panel for my ac/heat on my 2003 3.1L grand prix. I have the dual climate control panel. What i'm wondering is if I could use a single climate control panel instead of the dual.. Apparently they have the same pin configurations and one fella on youtube was thinking about trying it, but for whatever reason ended up not doing so. Anyone ever do this? The dual climate controls are just stupid expensive ($250 usually for new). But the single climate control versions are alot cheaper and more plentiful. I'm assuming it will just control both actuators when you select the temp on the panel..
    For any wondering, the issue my current panel has is the vent directional toggle seems to be worn out. It feels lose and doesn't really move the direction of airflow when you adjust.. You have to just pray when you change it around that it works...
  2. #2 Re: 2003 3.1, ac control panel
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    See my reply to http://www.grandprixforums.net/threa...nterchangeable.
    Basically, I'm almost sure that the position signals are reversed between the LH and RH actuators, therefore, without inverting the signals (aka if you just spliced the signal wires together etc.), you would have reversed Hot and Cold on the driver's and passenger's side.
    Perhaps a voltage inverter would work, but without knowing exactly how the blend doors work, it's hard to say.
    As far as I can tell, the single hvac units only have one big blend door and one RH actuator.
    Basically, I would find a junkyard near you, or PM me since they are stupid plentiful near me (seriously), and I have a working one lying around!
    But it SHOULD be theoretically possible. Hope this helps.
  1. Climate Control Panel Question
    By GOLD04 in forum 04+ Specifics
    Last Post: 08-22-2017, 04:14 AM
  2. U1153 lost communication with climate control panel.
    By markpa in forum General Tech Discussion
    Last Post: 11-28-2016, 07:44 PM
  3. where to find a climate control panel 04 gp gt heated seats
    By trucker1211 in forum Wanted To Buy - Parts
    Last Post: 07-24-2013, 08:38 AM
  4. Car won't start after messing with window control panel.
    By Ghozt in forum General Tech Discussion
    Last Post: 05-13-2012, 09:07 PM
