Thread: Time for a new Condenser?
Results 1 to 7 of 7
  1. #1 Time for a new Condenser?
    Mar 2017
    Pacific Wonderland
    I like preventative maintenance, so maybe I'm just being too sensitive here.
    When I turn the AC off, I can feel the engine sort of shake a little. It runs smoother with the AC on, which seems counter intuitive to me. Also, when I shut the engine off I can here a slight hissing noise coming from the condenser area, but it's been like that for months and I still have good AC so I'm not so sure it's a freon leak but I've been wrong before. Lastly, it seems to drip quite a bit out of the drain plug, but this is my first car with working AC so I dunno how much is normal.
    Am I just paranoid?
  2. #2 Re: Time for a new Condenser?
    The compressor makes pressure so it's not uncommon to hear it making noise right as you the shut the thing off. If it was a leak, you'd lose AC all together so that doesn't sound like your issue.
    Water dripping can vary some, depending how hard the system is working and the temps outside. Most cars make pretty decent puddles under the car when just sitting there.
  3. #3 Re: Time for a new Condenser?
    Mar 2017
    Pacific Wonderland
    Isn't the compressor on the passenger side? The noise I hear sounds like a tire leaking on the driver side, hence why I thought it was a condenser issue. I haven't taken the time to see how long it takes but it'll hiss for at least a few minutes.
  4. #4 Re: Time for a new Condenser?
    I mean the system as a whole, you have lines running from passenger side to the drivers side that lead back to the firewall. Certain parts of the system are under different pressure's and you can hear it bleeding off.
    Again if the AC works and cools like normal, nothing should be wrong. Replacing a condensor when it's not leaking or allowing the system to function normally won't help.
  5. #5 Re: Time for a new Condenser?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Higher humidity makes for more drippage..... My $0.02. Don't sweat it...lol.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #6 Re: Time for a new Condenser?
    Mar 2017
    Pacific Wonderland
    Ok fine guys, I'll quit worrying.
  7. #7 Re: Time for a new Condenser?
    GrandPrix Junkie
    St. Louis
    Yep, the hiss is the pressure in the system equalizing after it's shut down. Totally normal.
  1. Replacing AC Condenser
    By Exile in forum General Grand Prix Discussion
    Last Post: 08-10-2016, 08:52 AM
  2. AC Condenser and Evap
    By theclarks1 in forum General Tech Discussion
    Last Post: 08-04-2012, 11:13 PM
  3. AC condenser testing?
    By codysGS in forum General Tech Discussion
    Last Post: 05-18-2011, 08:23 AM
  4. 05 GTP Condenser
    By dsteinmann in forum General Tech Discussion
    Last Post: 05-16-2011, 05:46 PM
  5. air conditioning condenser
    By Hosscat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 06:58 AM
