Thread: Replacing AC Condenser
Results 1 to 10 of 10
  1. #1 Replacing AC Condenser
    GT Level Member Exile's Avatar
    Chicago
    Hey Everyone,
    How much of a PITA is it to replace the AC condenser on a 2001 GTP? What all is involved?
    Mine has severe leak. Leaks out an AC charge in about 48hrs. Dye confirms it.
    Thanks for input...this forum is the best
    2001 Black GTP Special Edition
    KYB Excel-G struts, Dorman & GMPP swaybars, Dorman/WBS trailing arms, K&N CAI, ZZP 3" DP, Thrush GP, all new calipers
    And the GP appropriate gas cap fender rust
  2. #2 Re: Replacing AC Condenser
    derp.
  3. #3 Re: Replacing AC Condenser
    Kemmerer, Wyoming
    Quote Originally Posted by Exile View Post
    Hey Everyone,
    are you sure it is the ac condenser? I had an ac leak, and it was just the nipple near the condenser that needed replacement.
  4. #4 Re: Replacing AC Condenser
    Dammit, he did say condenser, I read compressor.
    Remove the fans, remove the rad hoses and transmission cooler lines, raditor then can come out and you have full access to the condenser.
  5. #5 Re: Replacing AC Condenser
    Yup.. what 5 said. Pull the rad and it's cake
  6. #6 Re: Replacing AC Condenser
    Antioch, IL
    It is pretty dam easy, 30min and its all out
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Replacing AC Condenser
    GT Level Member mguzzo's Avatar
    Buffalo NY
    its possible to pull the condenser without pulling the radiator. it's a tight squeeze but it can be done especially if you can't get the trans lines off the radiator.
    also replace the accumulator / dryer when you replace the condenser. and don't forget to lube O rings with some PAG oil and keep it all clean.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  8. #8 Re: Replacing AC Condenser
    Chicago
    Quote Originally Posted by SgtMarshal View Post
    Is that on the drive side of the condenser? Upper or lower part of it?
    The dye can been seen with a UV light right through the lower air dam on the front bumper on the driver side. Looks like it's right around where a mounting point is.
  9. #9 Re: Replacing AC Condenser
    Chicago
    Sounds like a mess of coolant... fun.
    Have a feeling those trans cooler lines won't easily budge either.
    Thanks for the info tho Five!
  10. #10 Re: Replacing AC Condenser
    Buffalo
    Quote Originally Posted by mguzzo View Post
    Im with you on this one
    didnt open a single coolant or trans line ....
  1. AC Condenser and Evap
    By theclarks1 in forum General Tech Discussion
    Last Post: 08-04-2012, 11:13 PM
  2. 89 GP condenser location
    By jasonbsb in forum General Tech Discussion
    Last Post: 09-08-2011, 11:54 AM
  3. AC condenser testing?
    By codysGS in forum General Tech Discussion
    Last Post: 05-18-2011, 08:23 AM
  4. 05 GTP Condenser
    By dsteinmann in forum General Tech Discussion
    Last Post: 05-16-2011, 05:46 PM
  5. air conditioning condenser
    By Hosscat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 06:58 AM
