Thread: 2005 ignition and door key the same?
Results 1 to 4 of 4
SaukRapids 2005 ignition and door key... 05-20-2017, 10:33 AM
Fivefingerdeathpunch Re: 2005 ignition and door... 05-20-2017, 10:49 AM
SaukRapids Re: 2005 ignition and door... 05-20-2017, 12:30 PM
stealthee Re: 2005 ignition and door... 05-21-2017, 12:37 PM
  1. #1 2005 ignition and door key the same?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    So our better remote landed on the grass from the 3rd story. Needed a door key just then.
    I guess we only have two ignition keys, unless its supposed to be the same key and maybe the ignition was replaced?
    I looked at both front doors to see if a lock had been replaced, but only one door has an actual key hole.
    The previous owner was decent. Might have to give him a call, huh? I dunno..
  2. #2 Re: 2005 ignition and door key the same?
    Yes, all the door and ignition keys have been the same since 1997 on grand prix's.
  3. #3 Re: 2005 ignition and door key the same?
    May 2016
    MN
    ..Bleh
    Thanks for the info, FFDP.
  4. #4 Re: 2005 ignition and door key the same?
    SWPA
    Sounds like the key hole is seized from non use. You can try some WD40 or some graphite lube.
  1. Door / Ignition chime
    By 02 GP GT in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2016, 09:34 PM
  2. ignition switch replacement 2005
    By Austins01GP in forum General Tech Discussion
    Last Post: 03-03-2016, 08:57 PM
  3. 2005 ignition switch replacement
    By jteske88 in forum General Tech Discussion
    Last Post: 12-23-2012, 02:35 PM
  4. 2005 GT Key stuck in dash mounted ignition
    By eebill in forum General Tech Discussion
    Last Post: 10-04-2009, 08:59 PM
