Thread: What do you think of this trans pan?
Results 1 to 13 of 13
  1. #1 What do you think of this trans pan?
    SE Level Member Felix's Avatar
    Jul 2016
    Just wanted to know if you guys think this thing is worth it - https://zzperformance.com/3800/trans...ssion-pan.html
    I do trans filter/fluid changes every 30k miles and this will really help reduce the mess since I can just drain the fluid and then drop the pans. But also wanted to know if any of you had experience with this pan and if it actually reduces heat by cooling the fluid?
  2. #2 Re: What do you think of this trans pan?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Not worth it, imo. There's a regular (dorman?) one with a plug. O'rielly even carries it, I think.
    If you really want to step up the pan, a few members discussed this one. No one has feedback on it ..yet. http://www.grandprixforums.net/threa...from-cartuning
    I like the cartuning one, just note a couple things. There's added capacity, but that takes up space. This pan will sit lower, not so good for lowered cars.
    The added fluid advantage would best be used with a cooler, adding a further step and expense.
    I was going to do all that when I did the Trans-go. Moved, so that took care of that. Maybe when it needs rebuilding.
  3. #3 Re: What do you think of this trans pan?
    Jul 2016
    Dont think I'll have problems with it taking a bit more space since my cars not lowered. So would I need to add an extra 3 quarts if I were to get this pan, or would I be fine running the same amount of trans fluid I usually refill (About 9 quarts)?
  4. #4 Re: What do you think of this trans pan?
    Jul 2010
    Coquitlam,BC,Canada
    I bought one used, but haven't installed it yet. I got it for a steal, and the drain plug was the only reason I wanted it.
    If you get one, you will need to drill and tap the drain plug as they are know to strip very easily.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: What do you think of this trans pan?
    Jul 2016
    Is that the zzp pans or car tuning one? If its the car tuning one it doesnt look that big.
  6. #6 Re: What do you think of this trans pan?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Felix View Post
    ZZP.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: What do you think of this trans pan?
    May 2016
    MN
    Cartuning one is a big ol' thing. Should catch a little cool air under there.
  8. #8 Re: What do you think of this trans pan?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by SaukRapids View Post
    I wonder how well it deals with speed bumps. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: What do you think of this trans pan?
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    I haven't hit my Cartuning pan on any speed bumps. My car is lowered but not much. About an inch with GMPP Koni kit minus 1/2 inch for drivetrain spacers:
  10. #10 Re: What do you think of this trans pan?
    May 2016
    MN
    Quote Originally Posted by bcmonzai View Post
    They advertise a significant cooling effect with this big pan. Have you seen a difference?
    Been waiting for an owner because I'm still waffling over it.
  11. #11 Re: What do you think of this trans pan?
    Surrey, BC
    My Scan Gauge died before I installed the Cartuning pan. So, I cannot confirm their cooling effect.
    I did get my Scan Gauge repaired and hopefully, the car should be back on the road next month. Will let you know.
  12. #12 Re: What do you think of this trans pan?
    May 2008
    Schuyler, NE
    Cooling is not really the reason for a deeper trans pan. They are used to keep the pump from sucking air.
    And, the zzp pan sucks. You have to fix the plug threads.
    Plus, it's a good idea to drop the pan anyways to clean the magnet.
  13. #13 Re: What do you think of this trans pan?
    May 2016
    Lincoln, Nebr
    I bought and installed the dorman pan from Adv Auto with no issues, it's got the drain bolt. Got it for $30 w/ a coup. For the price you pay, it's a huge benefit to be able to do a quick drain n fill.
  1. '04 Trans Swap - What parts should I replace on donor trans before installation?
    By zookman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2016, 06:50 PM
  2. 98 GP Trans, 03 Chevy 3.8L N/A & TRANS, Inner & Outer Rockers
    By robmurt90 in forum For Sale - Parts
    Last Post: 08-21-2015, 05:39 PM
  3. non-super 3.8 trans vs. supercharged trans?? Any difference
    By chicagochuck in forum General Tech Discussion
    Last Post: 06-19-2014, 11:54 AM
  4. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  5. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
