Thread: Humming Noise?
Results 1 to 8 of 8
  1. #1 Humming Noise?
    SE Level Member Felix's Avatar
    Jul 2016
    This is one of the weirdest problems I had yet with this car. There is an audible humming noise coming from the rear of the car. I've not clue what it is. Its only audible when the car is not moving (parked, stop light, etc.). Only weird thing I notice that happened was the car started off rough, kind of like the rpm bouncing a little bit and was going to stall, but it did not. After that it started up normal, yet now there is a sound. Any clue what it could possibly be? Car seems to be driving like usual.
  2. #2 Re: Humming Noise?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Fuel pump? Cycle key from "off" to "on" (not "start") a few times. Fuel pump primes for like 2-3 seconds at each "on". No radio, fan, etc & doors closed to minimize chimes. Maybe open trunk, too...
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Humming Noise?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    fuel pump running.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Humming Noise?
    St. Louis
    Not knowing what year GP you have, if it's got an external fuel filter I'd change it.
  5. #5 Re: Humming Noise?
    Jul 2016
    I have a 02 GP GTP. I'll try changing the fuel filter. That area looked a bit rusted last time I checked. Thanks for the replys.
  6. #6 Re: Humming Noise?
    May 2016
    Lincoln, Nebr
    Could be your exhaust vibrations combined with a worn out exhaust hanger. Long shot, but your options are pretty limited in the rear of the car.
  7. #7 Re: Humming Noise?
    St. Louis
    It likely is rusty. What you want to do in order to NOT twist off the steel line is to hold the line nut still and turn the filter itself. I'd soak it real good with PB Blaster or another good penetrating fluid before you attempt anything.
  8. #8 Re: Humming Noise?
    Jul 2016
    Noise disappeared oddly enough. Still going to change the fuel filter though. Yep that fuel filter is rusted to hell.
  1. 99 GTP Rear humming noise
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 08-16-2010, 02:24 PM
  2. humming noise
    By speed24 in forum General Tech Discussion
    Last Post: 07-01-2010, 02:25 PM
  3. Humming noise from rear of car
    By jokyfo in forum Tires & Wheels
    Last Post: 06-04-2010, 01:36 PM
  4. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  5. new humming noise??!!??!!
    By Morris 04 GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2009, 09:33 AM
