Scottydoggs
jack and support the car up, take pass front wheel off, undo both lines to the pump, have a pan handy fluid will leak out.
back under the hood theres two 13 mm bolts at 12 and 6 o clock that you get through the hole in the pulley. after its unbolted i pulled mine out through the pass side wheel well.
